smokinquack Posted May 20 Share Posted May 20 So my master cylinder went out, ordered a new one from autozone. Ordered a NM1494 cause it looked like my original. Supposed to be new. got one that looks like the picture of a M1494, which is rebuilt. I think their website has the wrong pictures, I think what I got would work, but I want to make sure I got what I paid for. Anyone with experience with this? Quote Link to comment Share on other sites More sharing options...
cny first gen 71 Posted May 20 Share Posted May 20 If it's rebuilt take it back get a new one. I would never use a rebuilt again! Check around. 1 Quote Link to comment Share on other sites More sharing options...
MC1of80 Posted May 20 Share Posted May 20 Believe it or not check Amazon. I purchased a few NEW Delco masters for the Montes extremely cheap. 1 Quote Link to comment Share on other sites More sharing options...
Whons Posted May 21 Share Posted May 21 I found mine on Rock Auto. Just had to reuse the little hold off valve that goes to the front brakes. put it in with a new power brake booster. works well looks just like original. 1 Quote Link to comment Share on other sites More sharing options...
smokinquack Posted May 26 Author Share Posted May 26 So that master cylinder wrong, bad or both. Got a different one that is correct. Took a long time to get system bled out, but now I got firm pedal but little brakes. Diagnosed it to bad power booster. Can I get booster out without disconnecting master cylinder again. Reeeealy don't want to bleed it again. Quote Link to comment Share on other sites More sharing options...
1970mcss Posted May 26 Share Posted May 26 You should be able to unbolt the master cylinder and carefully get the booster out and bolt the master cylinder bolted back on. I haven't done it but I think I read somewhere it could be done. Someone please confirm Quote Link to comment Share on other sites More sharing options...
cny first gen 71 Posted May 26 Share Posted May 26 I agree you should be able to get booster off without talking lines back off. Did you bench bleed the master before you put it on? Quote Link to comment Share on other sites More sharing options...
smokinquack Posted May 26 Author Share Posted May 26 yes I did bench bleed it. Defanetly have firm peddle. Car was idling rough when I test drove, turns out its cause I have a massive vacuum leak from my power booster. Quote Link to comment Share on other sites More sharing options...
Dtret Posted May 26 Share Posted May 26 9 hours ago, smokinquack said: yes I did bench bleed it. Defanetly have firm peddle. Car was idling rough when I test drove, turns out its cause I have a massive vacuum leak from my power booster. That will definitely cause a problem. Glad you found the easy fix, it generally doesn’t work that way for me. Quote Link to comment Share on other sites More sharing options...
jft69z Posted May 26 Share Posted May 26 10 minutes ago, Dtret said: Glad you found the easy fix, it generally doesn’t work that way for me. Me either. Quote Link to comment Share on other sites More sharing options...
smokinquack Posted May 27 Author Share Posted May 27 Just finished up this project, took the wiper motor off and the hood off to gain access. Running good, stopping good, Speedway motors had my parts, they used to be more of a race car shop but they have what I need for my Monte so big shout out to them. If you are ever in Lincoln NE check out their museum, it is super cool. First cars and coffee this morning there, I drove the monte (without hood) Quote Link to comment Share on other sites More sharing options...
Dtret Posted May 28 Share Posted May 28 No proof if there are no pictures. Lol. 1 Quote Link to comment Share on other sites More sharing options...
smokinquack Posted May 29 Author Share Posted May 29 OK picture of the new unit. Have no pics of cars and coffee but there was over 1000 cars there, most ever Quote Link to comment Share on other sites More sharing options...
NavyCPO Posted June 2 Share Posted June 2 On 5/26/2023 at 6:39 AM, Dtret said: Glad you found the easy fix, it generally doesn’t work that way for me. Me Either! Quote Link to comment Share on other sites More sharing options...
