Sign in to follow this
JerseyMonte
Hei distributor
Is there enough clearence to the firewall to use an HEI distributor I have a complete HEI system, didn't try it , but just judging it may be close. I have a stock 350/300 Car is on jackstands for the winter going through maintenance and up grades, Reduction gear starter, r and r exhaust recoat manifolds replace heat stove parts, new spark plug heat sheilds,heat riser, change engine , trans and gear oil.
Found out it has a 2.78 gear
Thanks
Share this post
absolutely it will. it's a close fit, you can only just get a single plug wire between the cap and the firewall.
i don't have a pic uploaded right now that shows it.. i'll have to find one later for you.
Share this post
It will fit (as it was said it will be close), my back plug wire boot almost was touching the firewall...this was on my big block.
Bill
Share this post
