flatmotor Posted May 19 Share Posted May 19 Still having trouble with a wire getting hot on the compressor switch on the housing.It is the wire that is tan/light green.But the 2 relays on top of the glove box are causing me trouble.I have jumped themm before but now I can't get the compressor to kick in.If I plug both in sometimes it will engage with the key on and not the a/c control.1 is the anti dieseling .I tried to jump the tan wire with the light blue but the compressor will not engage.This is about to drive me crazy,Thanks for any help Quote Link to comment Share on other sites More sharing options...
flatmotor Posted May 21 Author Share Posted May 21 The compressor switch will not cut the compressor on.I can jump the 2 wires and compressor will run all the time.Can you get that switch or how to bypass.Almost ready to rip all the factory out and put a Vintage air in. Quote Link to comment Share on other sites More sharing options...
1970mcss Posted May 21 Share Posted May 21 I wish I had more knowledge about ac to answer your question. My compressor is working but I had a bad high blower relay and I think all my freon is somehow gone. Quote Link to comment Share on other sites More sharing options...
flatmotor Posted May 22 Author Share Posted May 22 after more checking both of the switches that control the compressor and fan seem to be where things are hot so today I will put 2 toggle switches and seem if they get hot enough to burn.I'm just trying to get the wires to stop getting hot that they melt.I know you can't get those switchs anywhere.They mount on the heater and a/c control.Thanks for help. Quote Link to comment Share on other sites More sharing options...
jft69z Posted May 22 Share Posted May 22 How much current is that circuit drawing? Quote Link to comment Share on other sites More sharing options...
1970mcss Posted May 22 Share Posted May 22 1 hour ago, flatmotor said: after more checking both of the switches that control the compressor and fan seem to be where things are hot so today I will put 2 toggle switches and seem if they get hot enough to burn.I'm just trying to get the wires to stop getting hot that they melt.I know you can't get those switchs anywhere.They mount on the heater and a/c control.Thanks for help. You can still get the heater blower switches. My high blower relay went bad and then fried the heater control switch. I replaced both and now the blower is good but the freon needs to be charged. Quote Link to comment Share on other sites More sharing options...
flatmotor Posted May 23 Author Share Posted May 23 I put the 2 toggle switch in for test and the wires didn't get hot at all.Going to a friends house this morning he has a pile of Monte parts.He has a control hsg with the 2 switchs in it.Will try them.Leaving dash pad off for now.Thanks for help. Quote Link to comment Share on other sites More sharing options...
Chevy Dave Posted May 23 Share Posted May 23 If you jumper the low pressure switch your compressor should run. If you don't get cold air after doing this, you have a low refrigerant charge. If you get cold air with the switch jumpered, you could have a defective switch. If you don't understand the system, it is best to have a professional diagnostic it. I would not replace the GM system with an aftermarket system. 2 Quote Link to comment Share on other sites More sharing options...
flatmotor Posted May 24 Author Share Posted May 24 by jumping the switches it runs cold.Now finding the 2 a/c switch.Those 2 switches have points on them.Thanks for help.Finding someone that knows the old stuff is getting rare.We are all getting old.Just glad I bought this car new ii 71 and still drive it. Quote Link to comment Share on other sites More sharing options...
