Sjepps Posted May 22, 2024 Posted May 22, 2024 So... speedo doesn't work. Actually I'm not sure the dash gauges are working at all. Fuel stays stuck on full all the time, maybe that's normal? Anyway, previously owner stated that speedo would work if the cable was slightly unscrewed at the transmission connection, but it would then leak fluid out. Anyone have thoughts? I haven't gotten under there to look aside from changing fluids out so far. Quote
cny first gen 71 Posted May 22, 2024 Posted May 22, 2024 Possibly the inside cable is to long causing it to bind up aftermarket parts may not be exact, check the power and ground on gas Guage. 2 Quote
cbolt Posted May 22, 2024 Posted May 22, 2024 What about the other gauges? The speedo is mechanical and the other gauges are electrical so those issues will not be related. From what I understand, the part of the transmission where the speedo cable is connected does not normally have fluid and should be fairly dry all the time. (minimal fluid at the most) Like Steve said, the cable may be incorrect for the application or just worn at the transmission end. 3 Quote
DragCat Posted May 22, 2024 Posted May 22, 2024 2 hours ago, cny first gen 71 said: check the power and ground on gas Guage. this, a ground will cause the gauge to peg. 1 Quote
stangeba Posted May 23, 2024 Posted May 23, 2024 Here is a picture of my 71 Speedo connection at the instrument cluster with the cable assembly removed. The "clip" (bottom) is what holds the cable to the speedo. Make sure the cable assembly is fully pushed into the speedo. I remember one time my plastic gear, at the transmission end of the cable, was all worn out and needed to be replaced. You could jack up the car, unhook the cable at the transmission, verify the gear is not worn out or missing, then spin it with a drill mtr while someone is watching the speedo to see if it works. I don't know if spinning it with your fingers is fast enough but you could try. I remember having lots of fun when I added cruise control to my 71 years ago, WOW!! 3 Quote
cbolt Posted May 23, 2024 Posted May 23, 2024 16 hours ago, Sjepps said: Anyway, previously owner stated that speedo would work if the cable was slightly unscrewed at the transmission connection, but it would then leak fluid out. Makes it sound like the issue is at the transmission end, but thinking about this a little more I would say you definitely want to verify whether or not this is true. Just because the previous owner says something doesn't actually mean its accurate. 3 Quote
Sjepps Posted May 23, 2024 Author Posted May 23, 2024 Thanks for the responses guys. I'll put it on the lift and check everything when I can. Quote
Scott S. Posted May 23, 2024 Posted May 23, 2024 The cable ends might also be rounded off.... I've seen that happen if the cable was binding. They are just made of plastic, and if original, over 50 years old. 2 Quote
