LEMONHEAD Posted July 10, 2024 Posted July 10, 2024 My 1970 Monte has no Dash or Dome lights any idea what the problem could possibly be? I've checked all the fuses and my headlights tail lights and brake lights are all working. Quote
Rob Peters Posted July 10, 2024 Posted July 10, 2024 Does the dome light come on when the doors are open? If yes I would lean to the headlight switch. I think no matter what I would look at the headlight switch first since they both are related to the headlight switch. rob 6 Quote
willie Posted July 10, 2024 Posted July 10, 2024 Ron as Steve said, look to the head light switch but first take the small bottom left fuse out and clean both the fuse ends and the fuse tabs up first. I had a problem with that. 1 Quote
Rob Peters Posted July 10, 2024 Posted July 10, 2024 59 minutes ago, willie said: I am sorry thats Rob not Steve!!! That's OK Willie, I have been called worse...... Depending which Steve you were referring to. rob 1 3 Quote
cny first gen 71 Posted July 10, 2024 Posted July 10, 2024 10 minutes ago, Rob Peters said: That's OK Willie, I have been called worse...... Depending which Steve you were referring to. rob Hey wait a minute here 🤣😅🤣 1 1 Quote
TheBMan Posted July 10, 2024 Posted July 10, 2024 I agree with the others, check your headlight switch. Be sure the ground strap is present and secure. It's very common for them to be missing or to be loose causing all sort of electrical gremlins. 4 Quote
Scott S. Posted July 10, 2024 Posted July 10, 2024 Hi Ronald..... And welcome to the gang. Sounds like a missing ground somewhere. Mine was a thinner grey wire that wasn't connected just above the E brake pedal. 1 Quote
