G71 Posted September 2, 2024 Posted September 2, 2024 Hello i believe i need to replace the starter on my 71/350 when i turn the ignition switch i hear the "click" of the solenoid throwing out but no other movement. i went to rock auto and i see many options choices i was considering are 1)GM GENUINE 323255 Re-manufactured Automatic transmission; DELCO SERIES 10MT Direct Drive TYPE 101 HIGH TORQUE UNIT 2) AC DELCO either used or re-manufactured i would like to replace the entire unit with solenoid etc. any one brand that would be best for quality and direct fit ? Thanks Quote
cny first gen 71 Posted September 2, 2024 Posted September 2, 2024 I would avoid a remainfactored all together, I used a power master high torque in my 350 and 100 percent happy with it. Looks like an original starter. Got it from summit it's a new starter not remain. Around $150.00 1 Quote
jft69z Posted September 2, 2024 Posted September 2, 2024 I've had good luck with NAPA starters. Lifetime warranty on the new and reman units. 1 Quote
Scott S. Posted September 2, 2024 Posted September 2, 2024 Hi Pat, Montelishi came with one of those high torque "mini" starters, for clearance purposes around the headers. Works great for me. Just a quick question...... When you say all you get is the solenoid engagement, did you check the amperage of the battery ? I only ask because when mine went, I thought it was the starter going as it was doing the same thing. Had the starter bench tested and it was fine, just not getting enough power from the dying battery. 2 Quote
420ponies Posted September 2, 2024 Posted September 2, 2024 I'm using a 1997 Chevrolet Tahoe starter on my new 427 BBC, which turns this motor over very easy. 2 1 Quote
DragCat Posted September 2, 2024 Posted September 2, 2024 With a "click" double check the coil. Otherwise mini starter would be my choice Quote
Canuck Posted September 3, 2024 Posted September 3, 2024 A number of years ago my car wouldn’t start and I figured it was my 21 year old starter. I replaced the starter but didn’t fix the problem. I tested if I was getting power to the starter, etc and it seemed fine. It turns out that although my battery cables looked good the positive cable wasn’t carrying what the starter needed (likely corroded inside the cable). The way I tested for this is I checked if I had 12 volts to the starter then have someone try to start it while testing the voltage. In my case the voltage went to zero when they turned the key so that told me the positive cable needed replacing. I replaced the cable and all was good. 7 Quote
Scott S. Posted September 3, 2024 Posted September 3, 2024 Yeah, I replaced the cables when I replaced the battery too...... Just to be sure. Quote
Jeff Dodson Posted September 30, 2024 Posted September 30, 2024 On 9/2/2024 at 6:35 PM, 420ponies said: I'm using a 1997 Chevrolet Tahoe starter on my new 427 BBC, which turns this motor over very easy. Is this a MINI STARTER. I remember someone speaking about a mini high torque starter from a newer vehicle. I just don't remember what it was from or where I read it Quote
420ponies Posted September 30, 2024 Posted September 30, 2024 Yes this is. I believe I read it in a Chevelle Forum ,talking about different starters that will work on Chevrolet motors. It's half the size and is very well built as for the starter head. Uses the same starter bolts. Rock Auto (like $98 ?) I bought the o.e.m. replacement I think. I used the 1997 Chevy Tahoe style. 3 1 Quote
70SS396 Posted October 26, 2024 Posted October 26, 2024 If you have the original starter why not have it rebuilt at a local shop . It's not expensive and will last another 50 years. Quote
stangeba Posted October 26, 2024 Posted October 26, 2024 I remember when I had to hit the starter mtr with a hammer then it would start. Turns out the brushes were worn out, so I had them replaced. Years later I did have it rebuilt and as of last week, it still cranks. (I hope I didn't just jinks it) I am a stock kind of person, don't care for aftermarket stuff. 1 Quote
