Can somebody please post a pic of where the wiring goes down from inside the trunk down to the gas tank. For a 71 if that makes a difference..
13 hours ago, cny first gen 71 said:
It goes through the rear shelf area with a rubber gromet on drivers side. I can grab a picture tomorrow if you need it.
A picture would be nice. I'm putting my car back together and I see that there's multiple holes across the back. Does the license plate light wire go down in the middle?
First Picture is drivers side, the fairly new brown wire is to fuel sending unit. The ground you see is for trailer wiring.  The second Picture is pass side 2 wires there too not sure what they are for Or what the other wire is for but it is in tail light wiring cluster going across the rear.
4 holes, looking down while standing on the ground. Left to right. Small hole backup light, bigger hole fuel, double plug for license plate( small hole ) last small hole other backup light. Ronnie I told you two months ago to get that Upolstry to the shop  Lol . That’s going to hold up your whole project. You can also put your harness in and the plugs will be in the correct spot.
Thank you sir!
Thanks Dennis! Regarding the upholstery I think that I'm just trying to avoid the sticker shock.. 🤣
  • Haha 1
I totally understand. lol.
Definitely gonna be sticker shock no Matter what you go with. Upholstery is not cheap.
1 hour ago, alain boileau said:
🙂I agree restoring an interior is very expensive especially if you do a complet interior
Alain🙂
I'll tell you I wasn't able to get mine from legendary because at the time they didn't have pattern for front bench seat but really worked with me because I offered mine as a pattern but it was not in good enough condition for them to work with to make a pattern. I went with someone else and was ok but definitely not the same quality. Great people to work with which why they have such a backlog. Just my opinion.
