kpcsgasp Posted October 17, 2024 Posted October 17, 2024 I need to realign my hood. I think the cause is from opening it up so many times during shows. should I adjust the rear bolts only or all four. I just don't want to make it worse than it it is already. 1 Quote
jft69z Posted October 17, 2024 Posted October 17, 2024 Start by dropping the hinge at the rear bolts a little. 4 Quote
Leghome Posted October 17, 2024 Posted October 17, 2024 3 hours ago, jft69z said: Start by dropping the hinge at the rear bolts a little. Or raising the front. This is the easiest as on bolt versus two for the back and the one to the firewall 3 Quote
jft69z Posted October 18, 2024 Posted October 18, 2024 11 hours ago, Leghome said: Or raising the front. This is the easiest as on bolt versus two for the back and the one to the firewall I'd still start with the back, that hood is really high. Loosen the back bolts a little, have someone push up on the front of the hood, then tighten them back up. At any rate, a little bit at a time.... You don't want to 'bow' the hood in the middle though. It's all about geometry, Larry is right though, to lower the back of a hood, you either lower the back two bolts, or raise the front two. Sort of opposite what you would normally think possible...At any rate, make sure when you're latching it at the front, the hood isn't bending in the middle, if that's the case, readjust to get it level. Realistically, the hinges may be worn out, and you may not get it adjusted properly if that's the case. Believe it or not, the factory assembly manual has a little diagram that helps as a starting place, using a couple gage holes in the hinge. Still, if the hinge is shot, it won't help. Fine tuning will be necessary, but it's a start if you were putting the car completely back together from scratch. 7 Quote
Leghome Posted October 18, 2024 Posted October 18, 2024 that is the first time i have ever seen that diagram Quote
420ponies Posted October 18, 2024 Posted October 18, 2024 Oh, This guy( Joe T), has alot of stuff we don't see. He is like "The Dude" on this stuff. A lot of the guys that work on this stuff know it, just don't show it, but if you ask them they are more willing to show you. I had another issue with my Monte( really?) and Joe T was the first one I contacted about it. This, and many other things on this site, are why I stay tuned. That' s why its the FGMCC!!😊 5 1 Quote
jft69z Posted October 18, 2024 Posted October 18, 2024 32 minutes ago, 420ponies said: That' s why its the FGMCC!!😊 Thank you, Jim! I managed to find that info before foot (feet?, both were worked on today) surgery this morning. 😄 4 Quote
cny first gen 71 Posted October 18, 2024 Posted October 18, 2024 40 minutes ago, jft69z said: Thank you, Jim! I managed to find that info before foot (feet?, both were worked on today) surgery this morning. 😄 Hope the surgery went well Joe, get well as soon as you can but don't push it. I know telling Joe not to push it is like telling a bear not to crap in the woods 🤣 2 1 Quote
jft69z Posted October 18, 2024 Posted October 18, 2024 4 minutes ago, cny first gen 71 said: Hope the surgery went well Joe, get well as soon as you can but don't push it. I know telling Joe not to push it is like telling a bear not to crap in the woods 🤣 So far it's good, but anesthesia is still working. There's a boot on each foot, sort of look like Herman Munster now 😄. 5 Quote
Scott S. Posted October 18, 2024 Posted October 18, 2024 Kevin, Haven't you ever heard the saying "Don't open your hood to strangers" ? I found with mine that I had to remove shims (on top of the cowl/firewall) to bring Montelishi's hood down But there wasn't enough play to get it all the way down so I wound up shimming the quarter panels as well. Scott. 2 Quote
DragCat Posted October 18, 2024 Posted October 18, 2024 1 hour ago, jft69z said: So far it's good, but anesthesia is still working. There's a boot on each foot, sort of look like Herman Munster now 😄. Well now when your in the shop its really "boots on the ground" 🤣 4 Quote
DragCat Posted October 18, 2024 Posted October 18, 2024 2 hours ago, 420ponies said: Oh, This guy( Joe T), has alot of stuff we don't see. He is like "The Dude" on this stuff. A lot of the guys that work on this stuff know it, just don't show it, but if you ask them they are more willing to show you. I had another issue with my Monte( really?) and Joe T was the first one I contacted about it. This, and many other things on this site, are why I stay tuned. That' s why its the FGMCC!!😊 And if you're up to your elbows in it and clueless ( ask me how I know 🤣) you'll get the "CALL ME" pm unless hes already got your number 🤣 3 2 Quote
FrankOC Posted October 19, 2024 Posted October 19, 2024 16 hours ago, DragCat said: And if you're up to your elbows in it and clueless ( ask me how I know 🤣) you'll get the "CALL ME" pm unless hes already got your number 🤣 Yes, been there a number of times! 7 Quote
willie Posted October 19, 2024 Posted October 19, 2024 2 hours ago, FrankOC said: Yes, been there a number of times! Haven't we all!!! 3 Quote
Scott S. Posted October 19, 2024 Posted October 19, 2024 21 hours ago, DragCat said: Well now when your in the shop its really "boots on the ground" 🤣 Can't sneak up on the cat anymore.... Quote
RON T Posted October 20, 2024 Posted October 20, 2024 Hope yer able to run a marathon in no time ! 1 1 Quote
RON T Posted October 20, 2024 Posted October 20, 2024 My hood needs fine tuned. But evidently this isn’t a one man operation.. when I lower the rear, the hood goes forward too much. No way I’m trusting my wife to hold the hood while my head is underneath!! No way! Hahaha!… 😂 2 5 Quote
cny first gen 71 Posted October 20, 2024 Posted October 20, 2024 Yes definitely a 2 man job for sure and sometimes a real pain but with persistence and a little time it can be done. I did it 3 times on mine when I was messing with the hood. 5 Quote
Blackhawk Posted October 20, 2024 Posted October 20, 2024 2 hours ago, Ron Tevis said: My hood needs fine tuned. But evidently this isn’t a one man operation.. when I lower the rear, the hood goes forward too much. No way I’m trusting my wife to hold the hood while my head is underneath!! No way! Hahaha!… 😂 Have the hood lowered as far as possible to where you can barely get your arms in to loosen the hood to hinge bolts. The hood will only move when you push it when it's that low, and you can check your progress a lot easier. 1 Quote
Scott S. Posted October 20, 2024 Posted October 20, 2024 5 hours ago, Ron Tevis said: My hood needs fine tuned. But evidently this isn’t a one man operation.. when I lower the rear, the hood goes forward too much. No way I’m trusting my wife to hold the hood while my head is underneath!! No way! Hahaha!… 😂 Another wife that knows the value of a good insurance policy ??? 5 Quote
MI_Custumz Posted October 24, 2024 Posted October 24, 2024 I adjusted mine by loosening the hinge bolts to the fender just enough to hold. Closed the hood, pushed the rear down, and slowly lifted the hood just enough to tighten the bolts. Way easier than moving the hinge and checking each time. I also removed the grill so I could lift it easier without pinching my fingers in the grill/hood meeting area. It also helped by being able to see the hood bumpers in front and seeing if they needed adjusted. Quote
RON T Posted October 25, 2024 Posted October 25, 2024 On 10/24/2024 at 6:53 AM, MI_Custumz said: I adjusted mine by loosening the hinge bolts to the fender just enough to hold. Closed the hood, pushed the rear down, and slowly lifted the hood just enough to tighten the bolts. Way easier than moving the hinge and checking each time. I also removed the grill so I could lift it easier without pinching my fingers in the grill/hood meeting area. It also helped by being able to see the hood bumpers in front and seeing if they needed adjusted. Thanks 👍 Quote
Traveler Posted March 30 Posted March 30 On 10/17/2024 at 4:22 PM, jft69z said: Start by dropping the hinge at the rear bolts a little. Finally got to my hood adjustment and your advice was spot on, worked great looks good! THANKS! Now on to the side to side adjustment, little steps made great progress. 4 1 Quote
jft69z Posted March 30 Posted March 30 1 hour ago, Traveler said: Finally got to my hood adjustment and your advice was spot on, worked great looks good! THANKS! Now on to the side to side adjustment, little steps made great progress. Good! Glad it worked out. As you said, little steps, and close the hood (any adjusted panel actually) carefully between adjustments. 2 Quote
