Does anyone know the Ohm rating on the resistor wire to the ignition coil? Is it 1.35, 1.5, 1.6, or 1.8 ohms.? Also, can you use a ballast resistor to replace the resistor wire? I believe you can you just have to get the right Ohm rating. Let me know if anybody knows. I believe the voltage to the coil through the resistor wire should be 7.7 to 8 V correct me if I’m wrong.
John S
  • 2 months later...
Sorry  don't know the answer. But can you tell me what color the wires are to that ignition resister, I'm guessing your referring to the resister for the original points distributor
