Does anybody know where the green and yellow wires go?
One of the wires should be 12V positive, and the other 12V negative, and the pump completes the circuit.
Attached is a picture of a 70 Chevelle wiper motor and washer pump.
The sad part about buying "off the shelf, generic" parts is that you don't always get a complete item.
Another downside is wires aren't usually colour coded to original.
Those two wires should be fitted into a plug/block that attaches to the three point block that comes from the switch and feeds the two speed motor and pump.
I've included a '70 diagram that might help...... But I think, (if you don't have a diagram) that you'll have to test which wire operates which function....
ie. does the green wire run the blade motor, or the pump motor ??
Good luck.
Good luck.
Man, I instantly get a headache looking at schematics (?) like this.  No thanks… I’ll write another check …
I agree. Might as well be speaking to me in Chinese ( no tariffs).
  • Haha 3
