So i have new pan and pickup to install on my monte sbc..can this be done without pulling motor. Not to sound stupid. By looking under without "diving in" it seems possible
The short answer is no. You will have to at least raise the engine for the pan to clear the crossmember and the crankshaft.
I have  done it on small and BB. Remove fan and distributor cap  motor mounts. I have a curved wooden block that fits  the harmonic balancer that I jack the engine up from. You could lift it fom above as well.
Gotcha. So if i jack it up by balancer as yu state in guess in only has to go up a lil just worried wont line back up with mounting on motor mounts
F it. Be easier to just hoist out thx guys
Don't you have to solder the new pickup in place ? I would hate to have to do that upside down
Gonna either braze or my buddy that's gonna help cause lifting motor is just easier, is gonna tack weld which should hold. They are pressed on, but moroso says to braze..but yeah under car lil challenging
A quick tack weld would be just fine.
Can also use a brazing torch i guess thx again jft69z
 think
I would hesitate on using the harmonic balancer to raise the engine. I always use a block of wood under the oil pan, remove the bolts from the motor mounts and have a couple of 2 x 2 near to put between the motor mount pcs and have had no problem an a small block I do not know about the bb's. I had a friend who used his HB er and messed it up  and dang near messed up the whole engine but others have done it and had no problems. I try to err on the causious side
I’ve done it the same way Larry has done it. Then rotate the crankshaft so that the timing mark on the harmonic balancer is facing down or in the 6 o’clock position that will reposition the crankshaft counterweights so you will be able to get the oil pan out easily. I recently removed the oil pan on my car. You should have no problem.
John S
John S
Good to know on the 6 oclock. Im just gonna do with a hoist seems easier and alot less [censored] in the way..lol
1 minute ago, Scott S. said:
Yeah, that's one thing that duct tape just won't do.... :k
Lmao. Funny yu say that bought new throttle billet deal and summit sent one for a ford and im like ok i cab prilly make work wrong ...so broke the cable bushing. And have it ductaped to old cabke holder fir now ...kinda a joke wasnt gonna drive like that
Hey, if the Mythbuster guys can build a boat out of duct tape, it has it's uses..... :k
That was a great show. They also tested bullets underwater, but i aint  about to do that
I especially liked when they made a replica of Mr. Zorg's gun from Fifth Element.... 👍
Lmao . Thy did some cool [censored] guys are geniuses
Ahhhh....
Typical farm boys.
They just like to blow s*** up. :k
5 minutes ago, Scott S. said:
Ahhhh....
Typical farm boys.
Yep i can relate
  • Haha 1
But that also taught us how to fix things with what we had on hand...  ;)
Just make sure you have a good engine stand. A 4 leg is what I prefer, since my last incident .That engine fell against my arm and my Monte! Saved the Monte, broke my wrist. Oh well, live and learn. I have done these inside the car, like Larry did, no issues. Just got to have room to work. Lining up the pickup is crucial (same plane as on oil pan rail). Just a tack weld will do. They tap in snug, just an insurance as to not vibrate out. Torque spec it out.And remember, plastic sleeve and oil pump rod go in from the bottom. Patience is the key. Take your time, double, triple check things as you go along. But like you said, pull it, then change things that need changed. Better off that way. Who knows, maybe a motor mount is bad?
Yeah i was just gonna pull up an inch or so. Didnt wanna take headers off big pia ...long tube and unbolt tranny.   Well see gonna do this fri but if i find rear main seal leekin then ill pull it all.
I replace my rear main every time I've done it, no matter what.🙂
If i end up pulling it out out then for sure
