Windjamer14 Posted June 10 Posted June 10 What was the factoty calking used to join metal in the trunk ? Quote
Windjamer14 Posted June 10 Author Posted June 10 Yes is that what it isand where can you find it? Quote
cny first gen 71 Posted June 10 Posted June 10 It's available all over Eastwood, Amazon, probably any body shop supply place. Quote
GRAY 70 Monte Carlo Posted June 10 Posted June 10 The main thing about seam sealers is there are a couple of different types. I personally prefer the urethane based seam sealers. Another concern is some seam sealers say direct to metal sure require a etch primer or epoxy primer for proper adhesion. I prefer to use a epoxy primer let it dry completely then lightly scuff primer then apply seam sealers. You also need to let seam sealer completely dry before applying any top coats Quote
