Crankcase Pressure
Guest Phils72
Guest Phils72
I'm sure that i'm not alone with all the racers we have here. How did some of you deal with getting rid of your crankcase pressure problems. I don't want to vent into the headers, and some of the catch cans are really pricey. Need some good ideas.
I put a breather in each valve cover and connected them to a cheap catch-can that I mounted on the core support, it has a valve on the bottom so you can drain off the condensation that accumulates in the can
just thought I would share this with you guys... it's kinda longwinded.. but also has some fantastic information in it on the PCV system and dealing with crank case pressure!
http://www.hotrodders.com/forum/pcv-valve-171746.html?highlight=pcv+valve
