Mike 57 Posted March 3, 2011 Share Posted March 3, 2011 Pulled the engine to do the head swap and cam change. With head studs it is easier to do it on the stand. When I drained the oil I found a lot fine metal almost powder on the magnetic drain plug. What I found is that the cam gear had eaten into the face of the block. My cam gear has a torrington bearing on the back to prevent that issue but it seems like it failed to do its job. I will have to have the face of the block machined to install a hardened wear plate. That means a tear down, not what I was looking to do! I do not use a bypass on my oil filter so it caught 99 percent of the trash in the oil so the bearings look good, oil pump shows some scoring from the cast iron grit passing through the gears. There is some very light scoring in the cylinders, most below the oil ring travel. I feel lucky I found it now. Ordered new rings and bearings and should have it back together in a couple of weeks. I will post pictures when I have the opportunity. Quote Link to comment Share on other sites More sharing options...
CrazyDavey Posted March 3, 2011 Share Posted March 3, 2011 well it's good that you caught it Mike. Probably wouldn't have caused a major failure but surely some premature wear. Good time to make sure everything is right before you make that 10 second pass.... Quote Link to comment Share on other sites More sharing options...
7tonemonte Posted March 3, 2011 Share Posted March 3, 2011 Wow Mike, got lucky there! That stinks having to tear it back down again,but I guess it could have been worse Quote Link to comment Share on other sites More sharing options...
72MC Posted March 3, 2011 Share Posted March 3, 2011 Wow that blows Mike. Good you caught it now though. - Dave Quote Link to comment Share on other sites More sharing options...
Winston Wolf Posted March 3, 2011 Share Posted March 3, 2011 Where is the bearing? Was is not contacting the block when you installed the cam? Quote Link to comment Share on other sites More sharing options...
Monte7071 Posted March 3, 2011 Share Posted March 3, 2011 Man talk about lucking out glad you caught it before you tore it up. Quote Link to comment Share on other sites More sharing options...
dbreese Posted March 3, 2011 Share Posted March 3, 2011 Bummer Mike! At least you caught it before to much damage was done. What do you think caused the bearing to fail? You'll have that mill back together soon and running 10's without a doubt. David Quote Link to comment Share on other sites More sharing options...
71monteme Posted March 3, 2011 Share Posted March 3, 2011 Mike. that's a bummer. i feel your pain because after i got my aluminum heads on my engine. 2 of my SR lifters gave up and took out 2 lobes on my cam. glad you caught it before it got worst. thanh Quote Link to comment Share on other sites More sharing options...
Mike 57 Posted March 4, 2011 Author Share Posted March 4, 2011 Winston, I run a Cloyes billet timing set with a torrington bearing on the back of the cam gear. The bearing seems to have a little bit "noise" but it does not seem like enough to cause it to wear into the block. The thrust is controlled by an integral roller button built into the two piece cover. I know it was adjusted correctly. I think I will file it under "crap happens" and go from there. Thanh, sorry to hear about your troubles. What brand of S/R lifters were you running? Quote Link to comment Share on other sites More sharing options...
Monteman1971 Posted March 4, 2011 Share Posted March 4, 2011 That sucks Mike but at least you caught it....another reason why your glad you sold me those heads Quote Link to comment Share on other sites More sharing options...
Sam (Bones) Posted March 4, 2011 Share Posted March 4, 2011 Thanh, sorry to hear about your troubles. What brand of S/R lifters were you running? I'd like to know too, that's what took out my 468 Quote Link to comment Share on other sites More sharing options...
71monteme Posted March 4, 2011 Share Posted March 4, 2011 Mike they are comp cam. they been in the motor for 9-10 years. over 200 passes on them and a lot of street time. so it was time. the cam is back at ultradyne getting re-lobes. new lifters on their way. hopefully put everything back in a few weeks. just curious what you used for the thrust plate and bearing? thanh Quote Link to comment Share on other sites More sharing options...
Mike 57 Posted March 4, 2011 Author Share Posted March 4, 2011 Sounds like the lifters lasted quite a while. Good the cam can be fixed. Check above for the timing gear stuff. Quote Link to comment Share on other sites More sharing options...
