McCall72 Posted July 29, 2011 Share Posted July 29, 2011 Any one have any tool suggestions on separating ball joints? I'm trying to remove some coil springs and have bent through two of those pickle fork tools. (Cheap China metal). There's gotta be something better than that out there.... Quote Link to comment Share on other sites More sharing options...
Andreas Posted July 29, 2011 Share Posted July 29, 2011 I usually use a BFH (Big Friggin Hammer)... Just make sure that the coil springs are secured with chains or similar. Quote Link to comment Share on other sites More sharing options...
bobsmc Posted July 29, 2011 Share Posted July 29, 2011 simply strike the spindle with a hammer or use an air chisel to hammer the spindle in the area around the ball joint. or if you are not going to replace the ball joints ,i like to take the two bolts out of the lower c/a where it attatches to the frame with a jack supporting the c/a. then lower the c/a slowly until the tension is off the spring. reverse to reinstall. i think that this is an easy way to do front coil springs. just my experience. bob Quote Link to comment Share on other sites More sharing options...
McCall72 Posted July 29, 2011 Author Share Posted July 29, 2011 Bought one of these over at Harbor Freight for 20.00. Worked like a charm. Quote Link to comment Share on other sites More sharing options...
robs70monte Posted July 29, 2011 Share Posted July 29, 2011 More metal form china lol Quote Link to comment Share on other sites More sharing options...
McCall72 Posted July 29, 2011 Author Share Posted July 29, 2011 Yeah, I know right? Is anything metal made on our shores anymore? Quote Link to comment Share on other sites More sharing options...
