gprimm Posted May 6, 2012 Share Posted May 6, 2012 While getting ready to put the 700r4 in the Monte I cleaned and painted the crossmember. Now I would like to replace the rubber bushings that go on each end of the crossmember. Cannot find them at any of the parts stores. Any recommendations? Quote Link to comment Share on other sites More sharing options...
70mcarlo Posted May 6, 2012 Share Posted May 6, 2012 The Parts Place has them - part no. AT6545Z Crossmember Insulators (rubber) - $19.00/pair. They also have the brackets as well. They are also in Illinois. http://www.thepartsplaceinc.com/ Quick link is also in the FGMCC "Parts and Services" section. Quote Link to comment Share on other sites More sharing options...
Clever Idiot Posted May 7, 2012 Share Posted May 7, 2012 The Parts Place has them - part no. AT6545Z Crossmember Insulators (rubber) - $19.00/pair. They also have the brackets as well. They are also in Illinois. http://www.thepartsplaceinc.com/ Quick link is also in the FGMCC "Parts and Services" section. Just ordered mine, should be in in a couple days. Quote Link to comment Share on other sites More sharing options...
Clever Idiot Posted May 11, 2012 Share Posted May 11, 2012 Got them in that night, actually. I also ordered the bolts for the brackets - I had my original brackets blasted and powder coated with my frame and crossmember. The rubber bushings fit perfectly, and the bolts and nuts were perfect, too. Flange-head black oxide bolts, zinc nuts and lock washers. Quote Link to comment Share on other sites More sharing options...
gprimm Posted May 11, 2012 Author Share Posted May 11, 2012 I just cleaned, primed and painted mine and the rubber is great. Will replace the bolts, washers and nuts with stdainless steel. Replacing everything on the car with stainless. Quote Link to comment Share on other sites More sharing options...
