Guest Posted July 15, 2002 Posted July 15, 2002 Does anybody know witch wires would go to my HEI dist.? I can only find the one red wire, and the green wire for my tach. I would think there should be a third wire somewhere.
Mr70Monte Posted July 15, 2002 Posted July 15, 2002 those are the only ones needed, just make sure that the red one has full battery voltage while the motor is running (not running through the ballast wire or resistor).
Grease Posted July 15, 2002 Posted July 15, 2002 AD .....also remember the pigtail which comes from the inside of the HEI unit and plugs into the cap also , just behind the power and tach wires. mike
Guest Posted July 16, 2002 Posted July 16, 2002 That is part of my problem I cannot find the pigtail as the HEI is not stock the only wire I can find is the red one. I cannot find the three-prong plug to connect the wires for the electronic ignition control module. Does anyone know where I can find a diagram for this? I hooked up the red wire and did not get any spark.
Guest Posted July 16, 2002 Posted July 16, 2002 OH, silly me the pigtail out of the distributor goes to the cap, to simple! ------------------ LLOYD@firstgenmc.com http://home.attbi.com/~adgtrunklid
