Can someone look at this auction http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=33731&item=2435209711 and tell me if these gears will fit on my 12 bolt open 2:73 carrier. BTY what series carrier are these 2:73? I am assuming a 3 but I thought I read somewhere that they are a 2 and only good for a 2:73 or 3:08 gears. If thats so that means I will need a 3 seriers if I want to go with a lower gear. I am wanting a 3:42 or something close to that. As always Thanks for any input.
My Monte's
If it sounds like Thunder!!! Me and My Monte have just rolled in!!!
1970 MC SS or one heck of a clone Needs restored
1970 MC 350/350
1998 F*%& WindStar
2002 Dodge Ram
[This message has been edited by busmechanic (edited 10-03-2003).]
Here is what I have heard:
The 12 bolt Positraction carrier goes: series 2 = up to 2.90; series 3 = 3.08-3.90; and series 4 = 4.11 up
71 Monte 454 HO 5- Speed "FULMNTE"
01 Camaro V6
Andreas' Monte Carlo Site
Member NMCOA, FGMCC (Event Coordinator)
I believe that a 3 series carrier will accept any gear from 2.73 on up, I cant say I have ever heard of a 2 series carrier.The do make some 4 series gears that will fit on a 3-series center section.I just looked in Summit catalog and the Pinion is a different Diameter for a truck 12 bolt housing compared to a passenger car.So I dought that ring and pinion will work in your housing and now that I look at center secitons they seem to be different also.I believe a car center setcion uses the c-clips and I would assume a truck housing might have axles that are bolted in on the tube ends
Paul Carillon
71 ProStreet 454
My Web Page: www.carillon.net/sschevy
[This message has been edited by BowtieThunder (edited 10-03-2003).]
i have not checked into this yet personally,but i have been told by several folks that TRUCK 12 bolt parts do not fit
CAR 12 bolts . he says its from an 80 suburban so i recommend you to check with someone on this point . i hope i am wrong for your sake but i wanted to let you know cause i have heard that .
mike
Bowtie, 2 series posi carriers do exist. I have one.
The guts of a truck 12 bolt rear and passenger 12 bolt rear do not interchange - Dave
Bus, to the best of my knowledge, yes. - Dave
