Guest Posted November 12, 2003 Posted November 12, 2003 so, i got in my car after school today and put on my right turn signal and to my suprise they came on but failed to blink. I loked in the haynes manual but either i missed the part about turn siganls or it wasnt in there. So can anyone help me out, the light came on and stay on but dont blink--- all of the bulbs work and the weird part is that the hazard lights flash as usual. hope someine can help me out. Andrew
jim's 70 Posted November 12, 2003 Posted November 12, 2003 If all of the bulbs are good, try a new flasher. There should be 2 of them, 1 for the hazards and one for the signals. i have seen them go bad and only one side dosen't work. Does not make sense to me but it has been known to happen. Jim ------------------
Guest Posted November 12, 2003 Posted November 12, 2003 i one for the hazard is located on the fuse pannel, it is the silver canister thing(correct me if im wrong) but where is the turn signal flasher? Andrew
Rob Peters Posted November 12, 2003 Posted November 12, 2003 I could be wrong because it has been years since I changed a flasher in a First Gen Monte but if I am not mistaken, the turn signal flasher is located under the dash on the drivers side and someplace around the steering column. If I am not mistaken it looks similar to what you described. Rob ------------------ To access my website click on the picture or link below. My Two Girls http://www.cardomain.com/id/robsmodelamonte Go Car or Show Car, it doesn't matter, you are welcome here
wallaby Posted November 13, 2003 Posted November 13, 2003 That makes it about as clear as mud. "unless I'm wrong, I'm never wrong". But to be honest Rob, I couldn't remember either. LOL
Guest Posted November 13, 2003 Posted November 13, 2003 You probably have a bad bulb. They can come on and not flash and still be bad. It's a cheap fix and if it's not the bulb you can save it for when you do need one.
Guest Posted November 13, 2003 Posted November 13, 2003 after i found the relay i just wiggled it around a bit and to my delight the blinkers started to blink.... thanks for the help guys Andrew
Rob Peters Posted November 14, 2003 Posted November 14, 2003 Quote: Originally posted by Andrew72:after i found the relay i just wiggled it around a bit and to my delight the blinkers started to blink.... thanks for the help guys Andrew Where did you find the flasher. Was it on the drivers side, under the dash near the steering column or someplace else? Rob ------------------ To access my website click on the picture or link below. My Two Girlshttp://www.cardomain.com/id/robsmodelamonte Go Car or Show Car, it doesn't matter, you are welcome here
