FullMonte Posted September 3, 2003 Posted September 3, 2003 Since I will be replacing the manifold and installing a 4 bbl carb, I will replace the old stock points. Conventional wisdom is..."go with an HEI." Pertronix tech help said go with Ignitor II and a new coil. It will fit in the old distributor. Is this an effective, reasonable option, or should I spring for the extra $$ and go for a new distributor? George
Andreas Posted September 3, 2003 Posted September 3, 2003 My Monte ran the older Ignitor I for about a year without a flaw. Did not need a new coil. Installs in less than 15 minutes.... ------------------ 71 Monte 454 HO 5- Speed "FULMNTE" 01 Camaro V6 Andreas' Monte Carlo Site Member NMCOA, FGMCC (Event Coordinator) ------------------------------------------ ------------------------------------------ "It ain't a car if it's not a Monte"
Guest Posted September 3, 2003 Posted September 3, 2003 I dropped the Crane Cams version in my 71 SS. Quick work and it runs fine. $69 if I recall.
Guest Posted September 3, 2003 Posted September 3, 2003 Hey Hey I change mine to a stock HEI I think I payed around 10.00 for the HEI and I fell for the kit were they sent you a six gauge wire(I am not sure on the size of the wire) and the two ends one for the HEI and the other for the fuse block that was 50 + shipping oh well livew and learn Dave ------------------ http://datadave49.tripod.com/ </a> http://members.cardomain.com/datadave49
Guest Posted September 5, 2003 Posted September 5, 2003 i installed the performax 1 in my dads 56, summit said i needed run the flame thrower coil due to certain ohms.it ran great until my dad left the ign. key on for about 20 minutes. the performax two is suppose to have a safeguard build into it.my dad replaced the complete dist. with a rebuild mallory unilite(SMALL DIAMETER)for about 100.00. gene
kc8oye Posted September 6, 2003 Posted September 6, 2003 I got an HEI of ebay for $20 put another $20 worth of parts into it, and had a great working hei till a missplaced hammer blow prematurely ended the dist shafts life.. (until I get some mapp gas) heh
johnbu Posted September 7, 2003 Posted September 7, 2003 Quote: <font face="Verdana, Arial" size="2">Originally posted by kc8oye:I got an HEI of ebay for $20 put another $20 worth of parts into it, and had a great working hei till a missplaced hammer blow prematurely ended the dist shafts life.. (until I get some mapp gas) heh</font> If I replace my stock distributor with an HEI unit, what's the procedure to hook up the stock tach on my monte to the HEI unit. Can it be done?
kc8oye Posted September 7, 2003 Posted September 7, 2003 just hook it up to the terminal labeled 'tach' on the hei. that's all I did for my aftermarket tach that used to be wired to my ignition coil on my TBI engine Quote: <font face="Verdana, Arial" size="2">Originally posted by johnbu: If I replace my stock distributor with an HEI unit, what's the procedure to hook up the stock tach on my monte to the HEI unit. Can it be done? </font>
