ejw71 Posted September 8, 2002 Posted September 8, 2002 On a '70 is a device located on one of the brake lines between the master cylinder and the proportioning valve. It measures approximatley 2.5" X 2.5". It isn't used on a '71 Monte and probably not on a '72. What is it's purpose and what was done to the '71/'72s to elimate it? Thanks, Ed ------------------ '71 Black 406/700R4 '71 Sandalwood SS454 '71 in process Super Dark Green/346LS1/4L60E
montefrazer Posted September 9, 2002 Posted September 9, 2002 Originally posted by ejw71: On a '70 is a device located on one of the brake lines between the master cylinder and the proportioning valve. It measures approximatley 2.5" X 2.5". It isn't used on a '71 Monte and probably not on a '72. What is it's purpose and what was done to the '71/'72s to elimate it? Thanks, Ed That is the metering valve for the front disc brakes. On the frame in front of the rear axle is the proportioning valve for the rear brakes. What you see on the front frame rail is just a splitter and low fluid brake light switch. This was all combined into one valve for 71 and up and is on the left front frame rail. ------------------ Steve
ejw71 Posted September 9, 2002 Author Posted September 9, 2002 Steve, Therefore, it would be a mistake to eliminate it, right? Thanks, Ed [This message has been edited by ejw71 (edited 09-09-2002).]
montefrazer Posted September 10, 2002 Posted September 10, 2002 Originally posted by ejw71: Steve, Therefore, it would be a mistake to eliminate it, right? Thanks, Ed If you want the brakes to work right leave it there. If you want to live the No Fear life, take it out and see what happens. ------------------ Steve
