ejw71 Posted October 26, 2003 Posted October 26, 2003 Q1. Are 70-72 Monte doors interchangeable without mods? Q2. Will any 1st Gen power window door accept non-power windows without modification and visea versea? Q3. Will 71 door guts (windows, etc) fit into a 70 door without mods? Thanks, Ed
Guest Posted October 26, 2003 Posted October 26, 2003 I have a 72 drivers door on my 70. It is identical. Both were non-power windows.
Guest Posted October 26, 2003 Posted October 26, 2003 Hey Hey EJW71 I not sure what it is you are trying to do it sounds like you got a door that had power windows if that is the case take a picture of were the crank bolt in the old door and take a nother of the power door and see haw far off they are you might have to drill a hole or two and then again maybe not I am going to do just that putting power windows in doors that had cranks I got one picture of the power if you need it I can e-mail to you Dave
Chris Posted October 26, 2003 Posted October 26, 2003 The only difference between power and non power doors is the holes drilled for the wiring. Everything else is the same. Chris
