Guest supercoupe5 Posted August 7, 2007 Posted August 7, 2007 i have a column shifter and want to go to a overdrive trans. do i have any options on this. dont really want to put a console in it if i dont have to. thanks dave Quote
monte70car Posted August 7, 2007 Posted August 7, 2007 dave i know the part u need let me find the part # and ill pm it to u here is a link dave http://www.julianos.com/lokar_column.html Quote
Grease Posted August 8, 2007 Posted August 8, 2007 Supercoupe you should be able to install the cross shaft from a donor car which had a 200 or 700 trans ( the shaft from the frame to the trans) . Then your only problem would be the PRNDL1 in the dash is not exzactly correct. But the shifting will be fine . I havnet seen a PRNDdL1 for a column . Most likely someone sells one . You might try BowtieOverdrive.com Quote
