Looks great, Sam! I'm glad I got to see it b4 being painted.
Yea Sam, quit yaking and get back to work. Ha! Ha! Just kidding. Looks good. I await the finished product. I need to get some updated pics and post them. Not much of a picture guy.
Guest 72yellowmc
KIT????
yeah you know the ones they sell through summit jegs etc. they have the kits for 70 - 72 chevelles but i never see one for the fgmc, even though I think the 70 - 72 chevelle roll cage kit should fit the fgmc?? confused
Even though it's not gray metallic!
I'm guessing you were gonna paint it gray metallic???
Looks good in black though wink now paint it gray and we will tell you which looks better... lol
no way, can't find rustoleum in metalic
I want to get to the interior guy next week if possible
Sam that is looking great! You must have a mint in dynomat?
Ian
I used "fatmat" got 100 sq ft for $135.00, with some leftover, still have a little more to do
no I did not do the roof, I think there is enough left to do it, I did cut pieces to do under the door panels
Well I ordered 3 bulk Extreme Dynamat kits on Ebay. 36 square feet each kit. I will be doing the interior, Doors,Firewall, Floor,Roof, Seat Back and Rear shelf. I hope that will be enough.
It looks pretty simple to install,kinda like wallpaper My only concern is covering up screw and bolts holes that are pretty evident proir to installing the Dynamat.
Put screws in the holes to locate them, Use a roller to roll it down, and be careful the edges can be extreamely sharp on the foil after cutting. Tin snips seem to work the best to cut it. Good luck my entire inside including roof is dynomat xtreme. Didsnt quiet the car like i thought though for me anyhow i had a Resonance problem.
  • 4 months later...
Do you have any pics of the frame mounting and the holes you had to cut in the body? Did you weld it from under the car or cut large holes and weld from inside?
Thanks
actually I had mine professionally done, and yes they cut sections of the floor out to do it
