I need a full set of brackets for ac, alt, and ps. going to put together a 402.
I'm sure you will get alot of opinions. I used Ground Up, aka ss396.com. they have kits for all. Come with all the brackets and more importantly all the required hardware.
If you are not worried about casting numbers and date codes, I believe this is the best way to go. Just my .02
I just checked them out. now i know. I'll see what i find and if not they will be my backup
Just an FYI. 70 upper bracket that goes over the valve cover looks different than 71-72. Not sure if your going for the correct look or not.
I will always try to stay period correct I like original.thank you for pointing that out
