I want to add aftermarket gauges to my car and I'm trying to find a spot on the block for the temperature gauge. I am totally a novice when it comes to this stuff but does anyone know what this plug with the square is, and will using this spot work? I took out one of the bolts like the one next to the one with the square but none of the brass fittings would fit that hole. Thanks!
Yes, that will work. It may be difficult to remove. Make sure you drain the coolant otherwise you will have a mess on your hands.
