Guest larrydday Posted October 1, 2007 Posted October 1, 2007 Help my transmission is leaking where the speedometer cable is connected. Is there a gasket or o ring missing? Can some one tell me what the problem might be? Thamk you for any help you can give. Larry Day Quote
Guest Phils72 Posted October 1, 2007 Posted October 1, 2007 If it's a TH 350 or 400 there is a o-ring around the outside of where it goes into the tranny. Easy fix, just remove the bolt that holds the assembly in, and replace the o-ring. Quote
Guest larrydday Posted October 1, 2007 Posted October 1, 2007 It is a TH350. Is the o ring installed on to the end of the transmission mount where the cable attaches to the transmission. Like inside the speedo cable nut. Quote
Big Jim Posted October 1, 2007 Posted October 1, 2007 Get you a steel Speedo Gear Housing and replace the original aluminum houseing. That fixed my leak. Quote
