monte70z20 Posted August 18, 2019 Posted August 18, 2019 Putting inner fenders back in my 70 today and I purchased the battery tray support bracket. There is no instructions with the piece I purchased and I was given an unclear explanation where this mounts to the inner fender. Can anybody describe to me where exactly this little metal bracket mounts/bolts to or perhaps if possible to post a picture of it mounted? Hopefully picture of the bracket I attached below comes through. Thanks. Quote
MC1of80 Posted August 18, 2019 Posted August 18, 2019 Hi! The flat side withe the 2 nuts welded to it goes against the fenderwell. The short side goes to the bottom of the battery tray. Make sure you use a short bolt. Otherwise you risk the chance of putting a hole in the battery. I will try to get a pic. Quote
monte70z20 Posted August 18, 2019 Author Posted August 18, 2019 Awesome guys. Thanks for the great description and the picture. Helps a ton!!! Quote
