Anyone ever use the OPGI UCA & LCA?  Looking for opinions on what I should get for my 70.
Opgi is just a rebranded part. Go on eBay and do research and compare. I got mine from eBay. Much cheaper for the same part.
Those are the exact ones I have on my 70 SS. Idk if you are aware of or not but the grease fittings are on top, towards the frame.
You need to change the fittings to have access when it's all together.
did you just throw 90 degree fittings in them?
Yes, I replaced the originals with 90 degree fittings. But if I remember correctly, I had to have them pointing towards the coil.
