70Monterrs Posted November 24, 2007 Posted November 24, 2007 I am looking to convert my current 1970 Monte from a TH 350 to a 4 speed. I have a Super T10 I am getting rebuilt. I need pedals, bell housing, lines, clutch, shifter, etc. Please let me know what you have. please send pics if possible to michaelghampton@hotmail.com Quote
Mikstudie Posted November 24, 2007 Posted November 24, 2007 I did a conversion about 10 years ago and had a hard time finding parts. I searched junk yards and found a 69 chevelle and got the parts from it, perfect fit! Iwish you luck in finding what you need!! Mike Quote
70Monterrs Posted November 24, 2007 Author Posted November 24, 2007 I wish you could still find chevelles in junkyards especially 4 speed ones........ thanks Quote
Guest supercoupe5 Posted November 25, 2007 Posted November 25, 2007 this may help you a little bit. i dont think its a bad price either. dave http://www.ss396.com/mm5/merchant.mvc?Sc...SMISSIONSMANUAL Quote
Mikstudie Posted November 25, 2007 Posted November 25, 2007 Thats the stuff,I think I had to modify the push rod linkage to the clutch fork!I cant remember why but I had to!!! Mike Quote
kc8oye Posted November 25, 2007 Posted November 25, 2007 a 700r4 is a direct bolt-in swap.. don't have to modify anything except your kickdown cable bracket... :> oh yeah and getting the driveshaft shortened ~ Quote
Guest Evil Austin Posted November 25, 2007 Posted November 25, 2007 I actually am doing the same thing TH-350 -> Jerico 4 speed. The site I have found to be very helpful with KITS for this process is musclecarsonly.com . . . It seems to be a one stop shop with everything from pedal kits, linkages, z-bar brackets and even the rubber snubbers, return springs, and firewall grommets. Good luck ! -EA Quote
70 Iron Posted December 7, 2007 Posted December 7, 2007 Michael, I have the clutch pedal assembly,which includes the pedals,Z bar,frame bracket,ball,pedal rod,adjusting armand also the fire wall plate which the rod runs thru.If still interested ,PM or Email me. I will provide a picture.They come from a 70 Chevelle Terry Quote
Andreas Posted December 7, 2007 Posted December 7, 2007 The Monte has a specific Z-bar frame bracket, which is different from a Chevelle... No repros available... You can probably make a Chevelle bracket work, but it will not be 100% like stock... Quote
70 Iron Posted December 7, 2007 Posted December 7, 2007 Thanks Andreas, I've never noticed the monte frame bracket,glad you brought that up though. Terry Quote
