gareth001 Posted January 21, 2020 Posted January 21, 2020 Trying to figure out why the clutch rod from the pedal catches on the firewall at the top - I figure this bracket is mounted incorrectly. It's been welded onto a raised bracket - I thought this should be bolted directly to the frame on a '72? Quote
MC1of80 Posted January 21, 2020 Posted January 21, 2020 Looks to be some " backyard engineering" I have seen worse. Lol the bracket you have pictures should bolt directly to the frame. Maybe your binding issue is from the height of the installed set up? Quote
gareth001 Posted January 21, 2020 Author Posted January 21, 2020 3 hours ago, MC1of80 said: Looks to be some " backyard engineering" I have seen worse. Lol the bracket you have pictures should bolt directly to the frame. Maybe your binding issue is from the height of the installed set up? It would make sense - wanted to confirm before I take an angle grinder to the frame Quote
John S Posted January 21, 2020 Posted January 21, 2020 Here is a picture from my 1970 small block four speed Quote
