rsorg Posted February 9, 2020 Posted February 9, 2020 guys, is the ground wire supposed to be grounded to the fender , i have heard to hook it up or leave it disconnected, ? also i started my car and ran it for a while and on idle the under dash lights flicker a little is that normal, thanks roger Quote
Rob Peters Posted February 9, 2020 Posted February 9, 2020 Roger, yes, there should be a small wire comming off your negative battery cable end that would connect to your fender with a screw. When I first got my Monte that wire was missing and if driving at night when I would have my headlights on and turned on a turn signal all of the lights would dim with the turn signals flashing. Once I hooked that wire to the fender it corrected that issue. I do think there are other things that can cause lights to fluctuate but that would be the cheapest repair. rob Quote
MC1of80 Posted February 9, 2020 Posted February 9, 2020 X2 to what Rob said. Hook the smaller wire up to the fender. Quote
