willie Posted February 24, 2020 Posted February 24, 2020 Does anyone know where I can get a good complete set for all the trim mldg, at one time? Thanks Quote
72-CLASSIC_RIDE Posted February 24, 2020 Posted February 24, 2020 If not requiring NOS, I have seen several Postings for the complete lower molding trim less the Rocker moldings I believe on eBAY and think the Clips were also included. You may try there, Doug Quote
imr Posted February 24, 2020 Posted February 24, 2020 car-pak but they dont sell it as a kit. you will have to order individually. Quote
MC1of80 Posted February 25, 2020 Posted February 25, 2020 Willie, try The Parts Place. I believe either they or someone on eBay sells the lower trim clip/fastener kit. Not the tailpanel trim though. Haven't seen those. ☹️ Quote
imr Posted February 25, 2020 Posted February 25, 2020 amk might also sell a kit including for hardware Quote
G71 Posted May 20, 2020 Posted May 20, 2020 was looking for the clips myself as i am doing a repaint did you end up finding something suitable? whats the likelihood that some of the original clips can be reused? i see the clip kits are rather expensive Quote
willie Posted May 21, 2020 Author Posted May 21, 2020 Hey Pat I bought the set Tom suggested, I will use most of them. I still have some of my OEM stuff that I do plan on using also. Yes on ebay they are selling clips but crazy prices. Look up the parts place you should find what you need there, they have most of the clips. Except for the 72 rear trim. Like Tom stated, no one makes that clip. I had a parts car that I will use the clips from to finish this car. Quote
G71 Posted May 23, 2020 Posted May 23, 2020 thanks guys i am using the opg catalog for reference, so just to clarify.... i see the "rocker molding clip retainers 22pc kit " $60 and "body side molding clips 70-72 lower" $75 for the set am i correct in understanding that even the sets dont include the clips for the tail panel trim/rear trim (the bottom rear trim piece with the marker light between the back of the rear wheel and the rear bumper?) Quote
Leghome Posted May 23, 2020 Posted May 23, 2020 I bought a whole box of rocker molding clips for less than $10. That was a box of 25 or 50 clips. Quote
willie Posted May 23, 2020 Author Posted May 23, 2020 Yes Pat if I am not mistaking, those 2 kits cover everything on the sides of the car. Body side mldg covers all 10 pcs. And the rocker mldg kit covers the long trim on the bottom on both sides. If you have a '72 they do Not make the plastic clips for the 3" trim under the trunk lid from side to side. Maybe someone else can chime in on this to confirm but I think this to be true. Quote
Leghome Posted May 23, 2020 Posted May 23, 2020 I never found any for the rear 72 trim and I tried for 6 months. I ended up using four end clips to attach that trim which could be made easily. Thin metal strip with a 10/24 bolt/stud welded in the center. I have done this when I worked in a body shop years ago. Quote
G71 Posted May 23, 2020 Posted May 23, 2020 ok so the 72 trim with unavailable clips is the piece running horizontally at the base of the trunk? all other body trim clips are available 70-72? Quote
