201fireman Posted February 25, 2020 Posted February 25, 2020 I have Autometer electric gauges and it calls for the oil pressure sending unit shown in the link below. Where would this mount on a 489 where it wouldn't be in the way? https://www.summitracing.com/parts/atm-2242 Quote
MC1of80 Posted February 25, 2020 Posted February 25, 2020 Small block or big block? Small block- behind the intake near the distributor. Big block- above the oil filter. Both are stock locations for the factory unit. Just replace the factory for the aftermarket. Quote
201fireman Posted February 25, 2020 Author Posted February 25, 2020 Gotcha. It's a big block. I will look above the filter. I just wasn't sure if this was too big to go there. Thanks a ton... again! Now if I can find a set of headers that work that aren't $1,600 that would be great. Quote
MC1of80 Posted February 25, 2020 Posted February 25, 2020 I have the ole hooker super comp headers. 2in primaries and 3.5 collectors. Fit fine. No denting or squashing of tubes. Quote
201fireman Posted February 25, 2020 Author Posted February 25, 2020 I like the sound of that. Got a part number? What is your car? Mine is a 72 small block with A/C. I am swapping out for the 489 and not using the A/C (if that matters). Quote
MC1of80 Posted February 25, 2020 Posted February 25, 2020 I will find the part number and get it to you. I have a 70 SS454 With a 496. 1 Quote
DragCat Posted February 25, 2020 Posted February 25, 2020 9 hours ago, MC1of80 said: I will find the part number and get it to you. I have a 70 SS454 With a 496. Man I just dig that picture ! Mine should be on the track this spring Quote
MC1of80 Posted February 25, 2020 Posted February 25, 2020 Take pictures!!! 😁 For some reason I thought I had super comps. The part number is 2455HK. They have the same primary size-2" and collector size-3.5" as the super comps. But looking at the pics they are 2455HK. Quote
201fireman Posted February 27, 2020 Author Posted February 27, 2020 Thanks a ton. I was looking at the two below over the winter so if that worked for you, one of them will work for me. Setting the motor in this weekend, then the work begins with the wiring, trans, fuel system, etc. https://www.summitracing.com/parts/hok-2455-2hkr/make/chevrolet/year/1972/model/monte-carlo https://www.summitracing.com/parts/hok-2455-1hkr/make/chevrolet/year/1972/model/monte-carlo Quote
201fireman Posted February 29, 2020 Author Posted February 29, 2020 Any word or opinion either way on header studs? Stainless or not? Quote
