Finishing the SB to BB swap in my 72.  Can anyone tell what a where I can get a smaller diameter brake booster? I want a smaller on to allow for my custom tall valve covers.  Thanks.
I got mine from I believe inline tube or the right stuff. Have it on my 70 SS. I believe it's a 9" dual diaphragm with a stock look.
I have stock valve covers with a 3/4 spacer. No clearance issue.
Thanks.  What do I have to watch for when I look for one? Rod length or anything?  Any thoughts on hydroboost?
I would keep it simple and go with vacuum if you can. At the time I thought my engine was not making enough vacuum so I went with Hydroboost from Hydra-tech. Its a really nice system but it will cost some bucks. If your gonna do it do it right.  Another guy had a great write up on the install process and parts if your interested I pasted the link below. On my install I ran the lines through the fender.
https://www.pro-touring.com/threads/71471-Hydroboost-Installation-w-pics
The one I have is made for a Chevelle. Same as our Monte Carlo. The only thing is make sure the brackets from the booster to the firewall are for a Chevelle/A -body.
Ok, is there a way to tell if I am going to have vacuum issues by my cam specs? Also, what 9" booster would work. Any ideas?  I am going to look into the hydroboost option but dam that's some coin.  It's an easier justification if I know I will have vacuum issues anyway. If Iam not and I can find a 9" booster that will work, it will be pretty tempting.
I believe there should be a way to tell by the cam specs, but I don't know how. You may want to contact the cam manufacturer or the engine builder. The place I got my cam from told me I would have enough vacuum  16 lbs. I had the motor built done by an engine builder. I didn't have enough vacuum for the brakes when I got her running.  Long story short. My engine builder screwed up on installing the intake and I had enough vacuum.. I figured that out after I went with the hydroboost. 😲
I know how it is when you have a valve cover you like . But it might be easier and cheaper to go with different valve cover if you can.
Good Luck !!!
On my 70 SS that is pictured above I also installed a vacuum pump, behind the washer bottle on the fenderwells just for the heck of it. I had it in stock. Still cheaper than a hydroboost system. Just another option.
  • 1 month later...
Hey Todd.
The vacuum pump kit I used, I purchased from summit. I looked real quick and didn't see it. I believe it was this one made by SSBC. The pic is just for a reference. Again, I purchased mine thru Summit.
