tranny fluid change
Guest silent72
hey wusup, im gonna change the fluid on my th350 this weekend. i've heard of people putting type f fluid instead of the dexron stuff. should i just fill her up with type f? people say it'll shift better due to some additives in the type f.
Type F has a higher "coeffecient of friction" (it's not as slippery) so it makes the clutches grab harder. It's generally not reccomended that they be mixed. If you make the switch to type F, it might be worth changing it, driving a few miles and changing it again for good measure.
you can also acchieve the same thing by using a shift improver like B&M's trick shift or some such with your Dexron-III/IV fluid.
dextron....but mine hasn't been on the road in 4 years
Wow you're lucky, a lot of mine is on the floor in my garage.
