DragCat Posted March 31, 2020 Posted March 31, 2020 Ok so I pulled the x-member and this part was on the drivers side but there was no similar part on the passenger side. I assume there should be but I don't know what its called so I can find one to order since I also assume it holds the x-member in place All help appreciated Quote
DragCat Posted March 31, 2020 Author Posted March 31, 2020 Nevermind, found what they are called and yes I need both sides lol Quote
Blackhawk Posted April 1, 2020 Posted April 1, 2020 https://www.thepartsplaceinc.com/part/1970/monte-carlo/automatic-transmission-related-parts/transmission-crossmember-related-items Otherwise I have a good set of OEM brackets and pads from a GTO that I didn't end up using. Quote
DragCat Posted April 1, 2020 Author Posted April 1, 2020 4 hours ago, Blackhawk said: https://www.thepartsplaceinc.com/part/1970/monte-carlo/automatic-transmission-related-parts/transmission-crossmember-related-items Otherwise I have a good set of OEM brackets and pads from a GTO that I didn't end up using. Thanks Cody, I ordered a set this morning. luckily I used their "related parts" drop down in the search function lol. Quote
