1Bad454 Posted April 7, 2020 Posted April 7, 2020 Hey guys take a look at this. Do I have the wrong fan shroud here? Any help would be greatly appreciated. Quote
Andy's Auto Posted April 7, 2020 Posted April 7, 2020 Looks good to me. A small block shroud hits the power steering pump. And yes, that full seven inches is not covered by the shroud. 1 Quote
stangeba Posted April 7, 2020 Posted April 7, 2020 A member posted this several years ago. I hope it helps. Bruce 2 Quote
1Bad454 Posted April 7, 2020 Author Posted April 7, 2020 Thank you gentlemen! I'm also trying to figure out if this is the correct factory radiator for the 454? What should I look for? Quote
1Bad454 Posted April 7, 2020 Author Posted April 7, 2020 Hey guys is this also the correct fan for the 454? I looked in the factory assembly book and it looks like it might me a possibility? Although it shows the LS6 with a larger fan (more blades) with a fan clutch. Quote
Andy's Auto Posted April 7, 2020 Posted April 7, 2020 With any big block it should be a 772 fan with a thermal clutch. Thing looks like it came off a stripper 6 cylinder Nova/ 1 Quote
