71MonteCarloMD Posted June 8, 2020 Posted June 8, 2020 I am checking with you all to see if I have wrong parts: 1. Rubber Door Jamb (u-shaped), the original have hole while the new one didn't as I am not sure if the previous owner drilled a hole or I have wrong one? The part number of new one is RPW40074 by TrimParts (see picture), what's the correct part number if I have wrong one or do I drill a hole in as the part fits in fine? 2. Trunk lid jamb - (round one that you attach to the edge of the trunk lid. I installed new trunk weatherstrip (TPW40010 by Trim Parts) which fits fine along the jamb ones which came in a kit (TPW401449 by Trim Parts). But I had difficult closing the trunk lid, had to really slam it to close, little difficult to open it - for testing purpose, I removed the trunk lid jamb on both ends, it closed much easier. Do I have wrong part? If so, what's the correct part number? Quote
Canuck Posted June 9, 2020 Posted June 9, 2020 Door jamb: you just need to drill the hole. That’s what I did. Trunk: I assume you are talking about the two round bumpers on the two corners. I have run into the same issue. My originals were a bigger diameter but thinner than the reproduction ones I got. Quote
71MonteCarloMD Posted June 11, 2020 Author Posted June 11, 2020 Aaron, thanks and will drill hole in it as I’m wondering why it is not pre drilled... Yes, you are correct as I was told I need 1/4 inch which it is but still hard to close, is it normal for new rubber bumpers? Quote
Canuck Posted June 11, 2020 Posted June 11, 2020 I had the same experience with the trunk bumpers. I have not ordered new ones since so not sure where to get correct ones. Quote
