1Bad454 Posted June 27, 2020 Posted June 27, 2020 Hey guys I'm trying to get my air suspension put together and working and I just noticed that this rod is broken. Can somebody please post a pick of what it looks like connected? I'm trying to figure out how I'm going to get everything functional again. Although I'm still missing the compressor and brackets... LOL! Quote
MC1of80 Posted June 27, 2020 Posted June 27, 2020 The broken end looks just like the good end only on the opposite side. Contact Dan, overdrive on here. He makes the links and also brackets for the air system. I have gotten a few from him. Extremely nice, quality factory looking pieces. I highly recommend him. He also makes the "slap stick" gate for the floor shifter, if you have one. I recommend this also. Hope this helps. 2 Quote
1970mcss Posted June 28, 2020 Posted June 28, 2020 Dito.... Dan is the man for brackets and links. He did a pair of brackets for me and there better than new..good luck with the compressor 2 Quote
1970mcss Posted July 7, 2020 Posted July 7, 2020 That looks like a winner, do you have a price in mind? Quote
1Bad454 Posted July 7, 2020 Author Posted July 7, 2020 2 hours ago, Alan said: Is this what you need Beautiful piece of artwork right there! I just picked one up from a member though. One thing that I would like to get is the rear shock protectors. Quote
overdrive Posted July 7, 2020 Posted July 7, 2020 Alan, I also make the shock protectors, if you can't find them. Dan 4 Quote
1970mcss Posted July 8, 2020 Posted July 8, 2020 I might have a used pair, but if Dan makes you a pair you cant go wrong. Quote
overdrive Posted July 8, 2020 Posted July 8, 2020 Thanks Paul. If you want, make yours available. I don't know how soon I'll be making another set, but I could make some in a month or two, probably. I'm working on designing slap shifting detent plates for 4 more types of shifters every evening. Dan Quote
1970mcss Posted July 8, 2020 Posted July 8, 2020 I will check my spare parts and see if I have a pair. Dan what does your detent plate run? Quote
overdrive Posted July 9, 2020 Posted July 9, 2020 Paul, the detent plates are $90, plus $5 shipping to anywhere in the US. Dan Quote
MC1of80 Posted July 9, 2020 Posted July 9, 2020 The "slap stick" detent plate that Dan makes are the bomb! Have it in my 70 SS, love it!!! Highly recommend! 1 Quote
1970mcss Posted July 9, 2020 Posted July 9, 2020 Ron,, I only have one side not a pair. Dan, I will let you know, Thanks 2 Quote
1Bad454 Posted July 9, 2020 Author Posted July 9, 2020 On 7/7/2020 at 7:52 PM, overdrive said: Thanks Paul. If you want, make yours available. I don't know how soon I'll be making another set, but I could make some in a month or two, probably. I'm working on designing slap shifting detent plates for 4 more types of shifters every evening. Dan Nice work Dan! How much are they? I do not need them painted as I'm having all of my suspension parts powder coated. Ron Quote
overdrive Posted July 14, 2020 Posted July 14, 2020 Thank you. They are $115 shipped in the US. Dan Quote
1Bad454 Posted July 14, 2020 Author Posted July 14, 2020 1 hour ago, overdrive said: Thank you. They are $115 shipped in the US. Dan Sounds good Dan. I will reach out to you in a few weeks or so. I'm in the process of having the remainder of my suspension powder coated and re-assembling it. Those shock protectors are key to completion. 1 Quote
overdrive Posted August 12, 2020 Posted August 12, 2020 Finished your set today. I didn't paint them, as requested. I bead blasted them and then coated them with WD-40 in a zip lock bag. They'll only need to degrease them for powder coat. Dan 3 Quote
Rob Peters Posted August 12, 2020 Posted August 12, 2020 28 minutes ago, overdrive said: Finished your set today. I didn't paint them, as requested. I bead blasted them and then coated them with WD-40 in a zip lock bag. They'll only need to degrease them for powder coat. Dan Beautiful work there Dan. rob 1 Quote
1Bad454 Posted August 12, 2020 Author Posted August 12, 2020 They look awesome! Check your in box. Thank you, Ron 1 Quote
Katman Posted August 25, 2020 Posted August 25, 2020 I have an extra set of brackets for the compressor. Apparently while collecting parts to revive my load leveler system I bought two sets about three years apart. They are still new in box. Quote
