Me and my mechanic just dropped my transmission to replace the clutch. I was so sure that my trnsmission was an M22 Muncie four speed, but after removing the transmission we discovered that it is a Super T10 instead of a Muncie. I had to send the clutch and presure plate back because the Muncie uses an 11 inch 10 spline, and the Super T10 uses a 10.5 inch 26 spline.The clutch that i am sending back is a Zoon HP race, and the one that i am getting is a Centerforce duel friction. What do you guys thiink? Is a Super T10 transmission as strong as a Muncie? Is a Centerforce clutch better than a Zoom, Ram,McLeod or Hays?
Guest Evil Austin
A super T-10 will hold up just as much as the muncie will to power, and the parts to replace if broken are much cheaper as well. I was considering selling one of the M-22's I have in the garage to a guy that had almost a matching number in his '70 camaro and it would have payed off the super T-10 almost to the penny. I think the trans you have now is a great gig, don't be angry its not a M-22 it will definatly do the job for you !
As far as the clutch goes, Zoom makes great stuff, and I have used centerforce along with a lot of other fellas I know and we all have had great luck with them !
You will be happy with your setup !
-EA
Guest ADGTRUNKLID
The T-10 will out weight the M22, that is why racers will go with the lighter M22 the prefered trany
Guest Evil Austin
Well if you want to go with lightest and strongest a Jerico 4 speed weighs like 68 lbs no fluid.
-EA
