Jsd454 Posted September 5, 2020 Posted September 5, 2020 Hello club members, My drivers power seat on my 1972 MC has stopped working. I want to start with the fuse box but not sure which one controls the seat. Can anyone tell me which one that would be and/or have had this issue and what I can do? The seat is stuck so close to the dash that it is difficult to even drive. I have pulled the seat out of the car at this point. Thank you for any advice you can provide. Quote
Leghome Posted September 5, 2020 Posted September 5, 2020 Before you pulled the seat did the motor make any noise at all. If not then it could be the motor. With the seat out of the car could you use a coouple of jumper wires to see if the motor makes a click or hums a little? Quote
Jsd454 Posted September 5, 2020 Author Posted September 5, 2020 Thank you Larry for your thoughts. I have not been able to rest the motor yet but it did not make any sound or movement prior to removing the seat. If it is the motor, are their replacements I can find? Quote
MC1of80 Posted September 5, 2020 Posted September 5, 2020 The power seat I believe is powered by a circuit breaker. Like the power windows. Check for power going to and from the breaker. Make sure you have power at the motor. If you do, then most likely the motor is no good. You can disconnect the cables from the motor and use a drill to manually move the tracks for a better seat position for the time being. Quote
Rare SS Posted November 19, 2021 Posted November 19, 2021 Just chiming in...You can also replace the motor with a cadillac motor Or a bench seat motor, which is much stronger. Jeff 1970 SS454 Quote
Rare SS Posted November 22, 2021 Posted November 22, 2021 Very knowledgeable man with power seat units, especially Bench seats! His name is Gary Thorne pins.thorne@gmail.com Jeff 1970 SS454 Quote
