I have a 6 inch cowl hood on my 72 MC. I am thinking of going with something with a little more radical look. I like the aero pro stock style hood scoops. Most of them are pretty big though. The smallest one that i have seen is 7 inches high, which isn't too bad considering my cowl is 6 inches. What do you guys think? Is there a limit to how high a hood scoop can be on a street car?
Guest Evil Austin
Depending on state (NC I have no idea) most have laws that a certain percentage of the window must be clear or it is a fix it ticket for vision obstruction.
Best of luck,
EA
I agree.
On the hood scoop idea there is or should I say was a fgmc near me that had a pro-stock scoop (smallest one they make) and I thought it looked awesome...funny thing though he had his car dynoed and only had 250 rear wheel hp (which isn't too bad) but he couldn't back the look up that he created with performance.
Bill
these big ole cars need a big ole hood to set em off.. im planning on getting me one as soon as possible..maybe a 4-6 inch
Guest 72yellowmc
These look pretty cool, I had one of these on my 82 camaro.
Overall: 31.5''L x 7''H
Base: 30''L x 15''W
487-4163
What other kind of hoods and scoops have you guys seen on Monte Carlos? Have any of you guys ever seen a Monte with a ram air hood? That would be kinda kool...
I haven't seen too many other than cowls, pro-stock, snorkel (yuck), one person I'm pretty sure had a GTO scoop on one.
We had a thread awhile back (I can not locate it for the life of me) where Scott/Heckeng photo-shopped a 442 hood on his monte...it looked pretty good.
Bill
If you drive your car on the street anything higher than 4" really reduces your field of vison. You will have serious blind spots. If you buy a 4" cowl hood make sure you get an iron clad warranty that alows you to take it out of the crate to check for flatness and get a full refund if it's warped. I'm speaking from experience here.
you prob can't find that picture cause we have to delete almost everything after a while
ask Scott if he still has it, that would make one cool hood, wouldn't give you anymore clearance but looks awesome cool
6" cowl and you want more!?!?!?
I only want a 2" cowl on mine smile
once I get the cowl scoop on, I want to cut a hole for the air cleaner, and add a carb and air cleaner spacer to push the air cleaner up into the cowl, and run the
K&N filter and Xtreme lid
My carb used to sit up inside of my cowl hood scoop when I ran a Holly Strip Dominator intake with a carb spacer. I now have a Dart intake and its not as tall as the Stip Dominator but the carb (Holley 650 double pumper) still gets to benefit from the cold air due to a Hilborn air breather that sits into the cowl scoop.I just think that it will look awsome when you look through the front of the Aero scoop and see the Hilborn breather.
