GraniteGuy88 Posted January 24, 2021 Posted January 24, 2021 My neighbor has had a beautiful "Old car" parked beside her house since she moved in a year ago. I never spoke with her until I happen to see her in her yard today. Told her I loved the car, she replied wanna buy it! She asked 2k, I offered $1600 and it was mine. Turns out its a 71MC. She claims its a 400 v8. It turned right over and started up but i noticed the carb was pouring fuel out the top pipe between the barrels on the back makin a mess. It sounded great but looped bad like a idling drag car for about 15sec before it died out. It has a big 4bl holley carb on it. I noticed the column has a shifter space/hole but its got a automatic floor shifter with pnd21. Did they make a 400v8 with a 2auto? Or is it all chopped up? Either way I feel it was well worth the cash. Wish i could figure out how to post a pic. Quote
714024SPEED Posted January 24, 2021 Posted January 24, 2021 Welcome !!! Seems like you got a good deal. They did make Monte carlo's with a 2 speed powerglide transmission but was a special order. Most of the Monte's I've seen with the small block 400 engine came with the M40 code trans (turbo 400). If the car was a factory column shift car the dash right above the steering column would have the gear selector and would tell you if it had a 3 or two speed trans. Good luck with your Monte Quote
Canuck Posted January 24, 2021 Posted January 24, 2021 Welcome! That is a good buy for $1,600. As said it was possible to get a 2 speed powerglide but only with the 350 2-barrel engine. You said it has “D21” which would make it a 3 speed. To add photos to your post you can click on “add files” at the bottom of the window when making a post. This is a great group here. Quote
MC1of80 Posted January 24, 2021 Posted January 24, 2021 Welcome! Sounds like a good buy. The needle and seat are stuck, causing the fuel leak and the rough idle before stalling. Ez fix. Sounds like the Monte was originally a column shifted car and was converted to floor shift. One way to confirm this is to look at the bottom of the speedometer. If it has P-R-N-D21 then it was originally a column shift. If not, then the column was changed. We love pics!!!! Hint hint.. lol Quote
Glen Posted January 24, 2021 Posted January 24, 2021 Welcome! MC1of80 is right...LIGHTLY tap the float bowls a few times with a screwdriver, pair of pliers or small hammer to stop that gas from pouring out of the vent pipe (ask me how I know 😬). And if you don’t plan on dropping the gas tank to dump the bad fuel, it sure wouldn’t hurt to throw a bottle of carb/injector cleaner in since it’s obviously been sitting for at least a year. I’d err on the side of caution and drop the tank to minimize making things worse. And, yes... PIX PLEASE! Quote
Dtret Posted January 24, 2021 Posted January 24, 2021 If the above carb/ fuel suggestions do not work pull the float bowl and replace the brass float that will be full of gas with a new one(it had a hole in it). IMO Quote
bigtankjones Posted January 25, 2021 Posted January 25, 2021 Welcome. Please post pictures of your car. We love pictures. Quote
