Is anybody running an X pipe? If so did you buy a kit or did you have a muffler shop put it on? Pictures would be nice.
I'm running an XPipe on my 70 SS. I had a 3" x pipe on it and now I have a 3 1/2" from the hooker comp headers to the X then out of the other half of the X is 3" to the rest of the 3" exhaust system.
I purchased the last Torque Tech kit and it was made with the 3 1/2" front section. I will try to get pics.
We also installed one into my son's GTO convertible. We used a universal x pipe kit from summit. 2 1/2" front to back. Here is a pic of my brother welding it up outside the car.
Are you looking at doing an x-pipe for performance or sound...or both?
The x-pipe will help over all for performance but in my opinion at the sacrifice of a true dual exhaust sound.
I decided against a cross over (x-pipe or h-pipe) on my Monte so I would have a different sound than most other people...it also helps that I have 3 1/2" Torque Tech exhaust from the headers to rear bumper, lol.
 I was considering adding one for performance but not sure if I want to go that direction due to the exhaust possibly hanging low due to the X? Is that correct? My engine is currently being built and it will be a dyno tested 600HP. I'm also glad that you mentioned how it would alter the sound because that would probably be a deal killer for me.
The exhaust doesn't hang too low of done properly.
My 70 SS, 496, 3 1/2" to 3" x pipe with ultraflow mufflers, I'm told, sounds amazing! Can't upload the video, 😡🤬
Here's a pic when I got the front end aligned to see how the exhaust  hangs.
That looks pretty sweet! I hope you could give the upload a try I'd really like to hear it.
Don't let it be a deal killer, the exhaust note will still be great with a cross over.
I am old school and like to be different. You probably could not tell the difference unless the two cars were side by side and then like I mentioned it's a preference thing. The only way I could explain the exhaust note would be to use a Harley...they come with a dual exhaust from the factory with a cross over (now a days even have a catalytic converter incorporated in it). Remove the head pipes and replace it with a true dual and you will have a sound more of a drum beat...hope that makes sense.
That's a good interpretation. I have a single pipe that was rusted, so I had an 2002 Midas exhaust with Ravin' Flowmasters on it. It does have the drumbeat. There's no H pipe or anything.
