Tim972 Posted March 7, 2021 Posted March 7, 2021 What’s the best fuel tank vent options for a 72’ with stock tank and almost all the original vent components missing? Run a remote vent off of the tank near the filler neck? Or is vented gas cap better option ? Thanks Quote
714024SPEED Posted March 10, 2021 Posted March 10, 2021 The cap should have a vent hole. You can also run a line from the tank sender off one of the original vent lines and put a fuel filter at the end ,just make sure you mount it higher than the tank. Quote
jft69z Posted March 10, 2021 Posted March 10, 2021 33 minutes ago, 714024SPEED said: The cap should have a vent hole. You can also run a line from the tank sender off one of the original vent lines and put a fuel filter at the end ,just make sure you mount it higher than the tank. That's exactly what I did. I used all 3 of the vent lines from the tank to the separator behind the back seat, and put the filter on the remaining/open hard line up on that set of lines up high. Fram G2 filter fit good. Tank is vented, no worry about fuel spillage with it mounted high, and I don't smell any vapors, at least to date.. 2 Quote
Tim972 Posted March 10, 2021 Author Posted March 10, 2021 Thanks for the input guys, I like that idea with the fuel filter. 👍 Quote
Tim972 Posted March 11, 2021 Author Posted March 11, 2021 5 hours ago, stangeba said: FROM MY 71 SHOP MANUAL IF IT HELPS ANY. Thank you Bruce 👍 1 Quote
