Tim972 Posted March 8, 2021 Posted March 8, 2021 Does anyone know if American Autowire uses all factory type connectors at the firewall? As in if I already have a new harness running to the rear of the car, would it plug into the American Autowire or would I have to swap in their rear harness out also? Thanks! Quote
Dtret Posted March 8, 2021 Posted March 8, 2021 Give them a call. They are awesome to deal with. They can also make what you want Quote
jft69z Posted March 8, 2021 Posted March 8, 2021 I recently put a full AAW harness in my car. The bulkhead connector appears similar, but the wire pinout may be completely different. I wouldn't plug nothing in unless you verified every single wire. Like Dennis said, call them up first. Quote
Tim972 Posted March 8, 2021 Author Posted March 8, 2021 Ok, I will see what they have to say. Thanks 👍 Quote
jft69z Posted March 8, 2021 Posted March 8, 2021 Which AAW harness is in the car now, front or rear? Did you have a full kit, or something someone else did before you got the car? Keep in mind, if any part of the harness is original, it's over 50 years old. Piece of mind would suggest replacing the rest of it new to eliminate any old, brittle insulation that could cause a fire, short, etc. Quote
Tim972 Posted March 8, 2021 Author Posted March 8, 2021 17 minutes ago, jft69z said: Which AAW harness is in the car now, front or rear? Did you have a full kit, or something someone else did before you got the car? Keep in mind, if any part of the harness is original, it's over 50 years old. Piece of mind would suggest replacing the rest of it new to eliminate any old, brittle insulation that could cause a fire, short, etc. Right now it’s all original and before I disassembled the car, it all worked properly. The reason for the question is I was considering swapping just the harness that runs to the rear of the car before I put the interior back in and eventually when I have it apart for to redo the A/C I would do the rest. I’ll probably just do it all now and be done. Quote
Dtret Posted March 8, 2021 Posted March 8, 2021 2 hours ago, jft69z said: Which AAW harness is in the car now, front or rear? Did you have a full kit, or something someone else did before you got the car? Keep in mind, if any part of the harness is original, it's over 50 years old. Piece of mind would suggest replacing the rest of it new to eliminate any old, brittle insulation that could cause a fire, short, etc. I’m driving with a fire extinguisher most all of mine will be original and I will never go # 1 before I drive the car 1 Quote
Tim972 Posted March 11, 2021 Author Posted March 11, 2021 I bit the bullet and ordered the American Autowire harness this morning. At this point, everything else has been replaced, no sense in skimping out now. lol Quote
jft69z Posted March 11, 2021 Posted March 11, 2021 That's a good call. Not worth burning the car down, or chasing gremlins from sins of past owners. Quote
Tim972 Posted March 11, 2021 Author Posted March 11, 2021 20 minutes ago, jft69z said: That's a good call. Not worth burning the car down, or chasing gremlins from sins of past owners. I agree 100% Quote
Dtret Posted March 11, 2021 Posted March 11, 2021 Come on. Isn’t part of the fun chasing the dahm gremlins? Quote
Tim972 Posted March 11, 2021 Author Posted March 11, 2021 1 hour ago, Dtret said: Come on. Isn’t part of the fun chasing the dahm gremlins? Haha, I actually don’t mind too much. I use to work at an auto electric shop when I was younger, now I’m an electrician and fix junk machines all night at work. But when I finally get to drive it, I hope it goes smooth lol Quote
Dtret Posted March 11, 2021 Posted March 11, 2021 2 minutes ago, Tim972 said: Haha, I actually don’t mind too much. I use to work at an auto electric shop when I was younger, now I’m an electrician and fix junk machines all night at work. But when I finally get to drive it, I hope it goes smooth lol I hate electrical work. Mostly because I’m to impatient to learn it. Home electric,love it but trying to figure out why a 1.5 volt wire won’t turn on a # 67 bulb. Screw that. I applaud the people that can though 1 Quote
