1Bad454 Posted May 23, 2021 Posted May 23, 2021 Hey guys I put in a new transmission pan (stock). I'm using a composite paper gasket similar to what the builder used. My question is should I put a little fluid on it or just put it in dry? It's been a while so I can't remember what works best... Quote
jft69z Posted May 23, 2021 Posted May 23, 2021 No fluid. I usually use Permatex 'spray-a-gasket' on paper gaskets like that. Couple of coats, let it tack up a bit & put it together. 1 Quote
