Good morning Y'all!  I just replaced the rear section of my 72, new floor, rear tail assembly.  I wasn't able to find my fuel sender wire.  As I'm going back to repairing my taillight harness I started looking for it and the only wire going back to the firewall was my fuel pump wire.  Is the sender "brown" wire part of the tail light harness?  i was going to order a replacement sender wire and it seemed a little short.  I might run a wire direct from the gauge to the sender to cure the problem, but if I can find where the sender wire is coming from, that would be helpful...suggestions?
Fuel sending wire should be tan colored.
