TonyS Posted May 29, 2021 Posted May 29, 2021 Hey I have a 1970 Monte Carlo and need a tilt wheel will a 1970 Chevelle tilt wheel steering column be a direct bolt in interchange and both are column shift thanks Quote
1970mcss Posted May 29, 2021 Posted May 29, 2021 They are the same column, should bolt right in. Good luck 1 Quote
RH 70 72 Posted May 29, 2021 Posted May 29, 2021 14 hours ago, TonyS said: Hey I have a 1970 Monte Carlo and need a tilt wheel will a 1970 Chevelle tilt wheel steering column be a direct bolt in interchange and both are column shift thanks I am thinking of doing the same on my 70. Did you find a column that matches the interior color? Quote
